John Deere 425 power steering hose replacement help
   / John Deere 425 power steering hose replacement help #1
Jeff4008
racine wisconsin
425 JD
Hello I need to replace the hoses on the power steering pump
Do I just remove and replace or is there something
I need to bleed after replacement.
The hoses have a hole in them from rubbing together over the years .
There is also a allen bolt in the center of the mount flange that holds
hoses to pump with two bolts on the outside edges
I haven't remove it yet looking for help with this repair so I don't muck it up thanks for your help
   / John Deere 425 power steering hose replacement help #2
The easiest and best way is to get the replacement hoses from Deere. You WILL pay a premium, but the hoses will fit without a fight. Ask if there are any gaskets or o-rings to be replaced.
I get to call the Deere dealer Monday morning for parts too.
   / John Deere 425 power steering hose replacement help #3
the system will self bleed , just replace the hoses, fire it up and turn the wheel lock to lock a few times then top off your hydro oil level.
   / John Deere 425 power steering hose replacement help #4
Need to replace power steering hose on jd 425, looking for any input. its left side hose that comes out of pump
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2018 HINO 258 S/A SERVICE TRUCK (A51243)
2018 HINO 258 S/A...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
1264 (A50490)
1264 (A50490)
2012 GENIE S-60X MANLIFT (A50854)
2012 GENIE S-60X...
