John Deere 425 plastic cam gear
   / John Deere 425 plastic cam gear #1
caseyvand
Dunvegan, Ontario, Canada
Did all John Deere 425s come with the plastic cam gear or did it change to metal some time during production? What is the range of hours of operation before the change needs to be made?
Thanks.....Casey
   / John Deere 425 plastic cam gear #2
Not all. I think it changed to steel around 1998. Failure of the plastic one largely depends on how well the tractor is cared for. I've read they can fail at about 700 hours or so. Mine failed 997 hours. But, I did take care to change the oil every 25 hours, always let it warm up and cool down as one is supposed to, and kept the valves adjusted.
Not too bad to change one out. Some have done it with the motor in the tractor. I removed the motor, and replace water pump, oil pump, governor gear, push rods, seals and gaskets. Removing the motor was the hardest part - alot of parts to get out of the way, and I had a stuck motor mount bolt.
UNUSED AGT 54" EXCAVATOR HYD BRUSH CUTTER (A51248)
UNUSED AGT 54"...
OLIVER DAHLMAN LOT NUMBER 244 (A53084)
OLIVER DAHLMAN LOT...
UNUSED NORTHERN UTV-50 AG MIST SPRAYER (A51247)
UNUSED NORTHERN...
2021 CATERPILLAR 420 XE BACKHOE (A51246)
2021 CATERPILLAR...
Genie GTH-644 (A50490)
2020 JOHN DEERE 331G SKID STEER (A51246)
2020 JOHN DEERE...
