John Deere 425 plastic cam gear
   / John Deere 425 plastic cam gear #1
caseyvand
Bronze Member
Dunvegan, Ontario, Canada
Did all John Deere 425s come with the plastic cam gear or did it change to metal some time during production? What is the range of hours of operation before the change needs to be made?
Thanks.....Casey
   / John Deere 425 plastic cam gear #2
Not all. I think it changed to steel around 1998. Failure of the plastic one largely depends on how well the tractor is cared for. I've read they can fail at about 700 hours or so. Mine failed 997 hours. But, I did take care to change the oil every 25 hours, always let it warm up and cool down as one is supposed to, and kept the valves adjusted.
Not too bad to change one out. Some have done it with the motor in the tractor. I removed the motor, and replace water pump, oil pump, governor gear, push rods, seals and gaskets. Removing the motor was the hardest part - alot of parts to get out of the way, and I had a stuck motor mount bolt.
Gravely 3000 RTV (A51573)
Gravely 3000 RTV...
2016 Hino 195h Truck, VIN # JHHSPM2H9GK001609 (A51572)
2016 Hino 195h...
2020 COLOMBO TM LOT NUMBER 215 (A53084)
2020 COLOMBO TM...
2010 Chevrolet Malibu LTZ Sedan (A51694)
2010 Chevrolet...
UNUSED RAYTREE RMBD50-50" DRUM MULCHER (A51248)
UNUSED RAYTREE...
Industrial Air Contractor Air Compressor (A51573)
Industrial Air...
