John Deere 4230 leak at steering column
   / John Deere 4230 leak at steering column #1
crossroadsd
Chase City, VA
John Deere, MF, Deutz, Case
We have a John deere 4230 with a leak at the base of the steering column. This is a late model with a telescoping steering column. It looks like the leak is right at the top of the metering pump. I have a I&T shop manual that shows a oil seal (#27 in there drawing) at the base of the steering column. I am hoping that I can pull the column and replace the one seal and be done with it.
Just wanted to get some input before I got into this. Most of what I have been able to find is related to a leak at the top of the steering column. One other thing I have noticed is that when cranking the front wheels will turn slightly. Not sure what this is an indication of.
Thank you for any advice you can provide.
   / John Deere 4230 leak at steering column #2
Early model 4230 had telescoping steering. Is your tractors serial number below or above 019558?
Thank You for responding.
The serial number is above: 027258R. However, it does have the telescoping steering. We bought this tractor used so I don't know what could have been done to it previously.
   / John Deere 4230 leak at steering column #4
IIRC seal(parts key 3) is what you need to replace to stop leak. Both old(early) & new(late) styled steering on 4230 could be tilt & telescope.
Thank You for your help. I will see about ordering parts and making repairs.
25 TANDEM DUAL GOOSENECK TRAILER (A58214)
25 TANDEM DUAL...
New/Unused CFG Industrial MX20R Mini Excavator (A57453)
New/Unused CFG...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
David White Meridan LT6-900 Level Transit, S/N D94224 (A59076)
David White...
(3) BUG REFLECTORS IN BOX (A58374)
(3) BUG REFLECTORS...
2013 JCB 3CX 4x4 Extendahoe Loader Backhoe (A55973)
2013 JCB 3CX 4x4...
