John Deere 4200 won`t start, please help!!!
/ John Deere 4200 won`t start, please help!!! #1
zdog
Was doing some backhoe work on my John Deere 4200 and when I got off to move the tractor forward I believe the tractor seat was not all the way down making the safety switch and the tractor stalled out. Now it will not start up again. I metered the seat switch and it was good, tried bleeding the fuel lines and the lines where they go into the injectors but still no luck. Can someone give me some ideas as to what I might look for or do to try and get it running again???? Thanks
/ John Deere 4200 won`t start, please help!!! #2
Does it crank? Something get stuck under the seat preventing the seat from making the switch? Fuses? Other safety interlocks (PTO etc.)?
Hope you get it going /forums/images/graemlins/smile.gif
/ John Deere 4200 won`t start, please help!!! #3
Are your shift levers in neutral and clutch fully depressed?--Ken Sweet
/ John Deere 4200 won`t start, please help!!! #4
Have a close listen behind the dash for a prety good " CLICK" maybe your fuel cylanoid isn't opening. Kinda hard to discribe the sound but it is a little louder and harder sounding than a electric points opening or closeing typ of sound /forums/images/graemlins/crazy.gif Mine has not opened "STUCK" before I just turned the key from off to the next position "ACC." a couple of times and it opened and started like it should. Hope it helps ya.
Yes the starter does crank over, and it is a hydro unit so no clutch has to be depressed........still trying like heck to get it going before shipping it off to the dealer!!! very frustrating!!! Thanks for the suggestions so far!!!
/ John Deere 4200 won`t start, please help!!! #6
Also try looking at the HST neutral switch. It's been awhile since I looked at one, but it is somewhere underneath the right foot deck on the pedal linkage to the HST.
That switch must be in neutral for the tractor to start.
/ John Deere 4200 won`t start, please help!!! #7
Sounds like a bad thermistor on the John Deere.....there has been a lot of these that have been problems on the John Deeere 4000 series ...a small easy fix.
/ John Deere 4200 won`t start, please help!!! #9
PROBLEM:
the fuel pullin circuit does not engage On examination of the solenoid the is evidence of oil within the solenoid which requires additional force to pull in the plunger Replecemnet solenoid reacts the same
SOLUTION:
Consider the fitment of a replacement Thermistor part no LVU10323 The thermistor controls the operation of the fuel shut off pull in relay Should the relay fail to engage the Thermistor may not allow an earth circuit for the relay thermistor may be disengaging prematurly to expell the oil behindn 6the plunger Addition lnfo: for cold conditions use a 5W 30 engine oil the lower viscosity oil will be displaced easier from within the solenoid to allow operation
John Deere thermistor/starting problems.
/ John Deere 4200 won`t start, please help!!! #10
Good deal, good link. I hope this fixes his problem for him. A good fix for less than 5 bucks is always good! /forums/images/graemlins/wink.gif
Hello.........Thanks to all that replyed. The thermister solved the problem. Went away for a few days and came home and saw the reply`s about the thermisters going bad so I called the dealer up and he had 1 in stock. Put it in and she fired right up!!!! All that frustration and down time or a $3.79 part!!You guys are all really great, and this forum is super!!!! Thanks again so much for everyone`s help!!!!
/ John Deere 4200 won`t start, please help!!! #12
That's great, I want to thank the guys here at TBN and I didn't even have a problem. I can even say how cool it is to see you guys helping us newbies out, I just wish more people could act the same way, we would have a much better world. Thank you.
/ John Deere 4200 won`t start, please help!!! #13
I found out the hard way on my JD 4400,luckily it was under warranty,JD replaced the fuel pump/starter and the problem was never corrected and they came to my house one day while I was out working on the tractor and the JD tech had the thermistor in hand,he installed it on the spot and I never had the problem again.
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Informational Lot - Shipping (A61306)
Informational Lot...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
2025 DIGMASTER DM100 EXCAVATOR (A60430)
2025 DIGMASTER...
2015 Ford Escape SUV (A59231)
2015 Ford Escape...
