John Deere 420 cranks, won't start
   / John Deere 420 cranks, won't start
Compression is 100# and 90# on the cylinders. I'm unsure on the control module. I'll have to look at that for sure.
Just a question here, someone told me to hold a ratchet on the front of the motor and turn the driveshaft by hand, I can't turn it, would that indicate my flywheel key is ok? I'm trying to rule out as much as possible before pulling the motor.
   / John Deere 420 cranks, won't start #12
If you somehow lost the key [ doubt it ], and the flywheel bolt was still fairly tight, the flywheel still could be hard to turn on the tapered crankshaft. If you go to the trouble to pull the motor [ not that hard ], AND pull the flywheel, I'd replace that sender just for the **** of it.. I still bet a barley pop on it being bad.... I don't remember a plastic magnet on the cast flywheel, but I don't remember a lot of things these days... :)
   / John Deere 420 cranks, won't start #13
The magnetic collar is on the crankshaft it is keyed too, It sits behind the ignition module, The flywheel has magnets that create flux for the stator as it spins.
I doubt that it will turn if the PTO and belt are still in place.
   / John Deere 420 cranks, won't start #14
Those compression numbers are too low. They're either wrong or they are the problem. Should be more like 165 psi.
   / John Deere 420 cranks, won't start #15
They are close to being worn out minimum is around 80 PSI with no more than 10 PSI difference between cylinders. So it might need to pull the heads and measure the bores down the cylinders. Also note to see if the pistons are std or .010, .020, ,030 size. I would check with boomers_influence@yahoo.com for the normal and max compression values because I've never have read where they are published at. But he might know since he is man with the knowledge.
I shot him an e-mail to see what he says on the values. I will report back.
   / John Deere 420 cranks, won't start #19
I've got a neighbor with same issue, JD 420 that turns over but doesn't fire. I've have read through 3 similar threads where the OP never bothers to post a resolution. GRRRRR.
How about it dustball? How'd things turn out for you? Any resolution?
   / John Deere 420 cranks, won't start #20
It is probably the ignition module and plastic rotor that has the magnets that trigger the ignition module which in turn applies that to the coil. There is a test in the manual to check that out.
Nissan Forklift (A55973)
Nissan Forklift...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2016 Nissan Pathfinder SUV (A56859)
2016 Nissan...
2024 JOHN DEERE 50 P-TIER EXCAVATOR (A52709)
2024 JOHN DEERE 50...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
