John Deere 4120 Hydro Problem
/ John Deere 4120 Hydro Problem #1
sidesteppers
grandview,tn
JD 4120 Hydro
I have a 4120 hydro with 350 hours. Problem is the tractor just stops in its tracks. The RPM's stay the same. I have to let off the pedal completly before it will move again. This seems to happen at any time, load or no load. Any ideas about what could be causing this. Just did run out of warranty!!
/ John Deere 4120 Hydro Problem #2
Are you getting any error codes?
/ John Deere 4120 Hydro Problem #3
Is your boot touching the reverse pedal? Is the error code light flashing?
Check the wiring to and from the pedals. Is the seat switch shorting out or not being depressed properly?
I am not getting any codes. I will check the wiring on the seat and the pedals. Thanks for the info !!
/ John Deere 4120 Hydro Problem #5
There are error codes for the forward and reverse pedal sensor being above and below normal and out of range/out of calibration. It's a ground and +5 volt operated device. So if the sensor (output) from a pedal is shorted to ground or plus 5 (or above) you'd get an error code. I would imagine the controller's input from the pedals has a small pull up or pull down resistor on it such that if that wire goes open, you'd get an error (never seen this not done, but don't have explicit knowledge about this design). The sensor supply voltage is also monitored and there are error codes for that having a problem or being out of range.
The instrument controller (dash board or ICC) has 34 errors it can detect, the transmission control unit (TCU) has 28 errors it can detect and the engine control unit (ECU) has 62 errors it can detect. All these have displays on the dash.
There are also a number of other measurements (things you can read from the controller) that can be made by a dealer (manual shows 11 pages of them, and then 40+ pages with details on the faults), and I suspect there are other error codes that are not listed in the manual (either they are rare or software updates added them).
So what's my point? Check things, but don't go too nuts about it. There is also the good news/bad news about any computer controller tractor. It takes a computer to fix a computer, but the computer can identify a lot of problems with wiring and sensors that could not be identified before. So if you've checked the obvious there is a point where the dealer has to show up and plug in some stuff. I know this isn't directly helping you, but if it keep you from tearing up things to check other things, it might help.
I suspect the long term success of the computer controlled tractor will boil down to how much does it cost to have the dealer come out, plug the tractor into the mother ship, and see what the problem is. I'm also curious if you'll be able to by replacement controllers in 15 years. It's not a technical problem, even if they redesign the controller boards. Time will tell.
Sorry I can't be more helpful or specific.
Pete
/ John Deere 4120 Hydro Problem #6
Could it be a problem with the seat sensor? Faulty seat sensor would stop the tractor and not move until completely release the hydro pedal. Probably would not have an error code.
/ John Deere 4120 Hydro Problem #7
I could get on my 4520 tomorrow, start moving, and get off the seat and see if there is any display given and let you know if you want.
Pete
I disconnected and cleaned the connections on the seat sensor and the pedal sensors. Everything seems to be working just fine now. I don't really know which one was causing the problem, but so far so good. Thanks for all the info.
/ John Deere 4120 Hydro Problem #9
I was going to chime in and mention this but Radman already did. Hopefully you fixed the problem and didn't cost anything. Good luck.
20 FOOT SHIPPING CONTAINER WITH CONTENTS (A68842)
20 FOOT SHIPPING...
1980 LOX  NITROGEN TRANSPORT TRAILER (A67714)
1980 LOX NITROGEN...
2008 Ford F-350 King Ranch 4x4 Crew Cab Pickup Truck (A66736)
2008 Ford F-350...
DYNAPAC  CP271 PNEUMATIC ROLLER (A67714)
DYNAPAC CP271...
Unused 2022 Hustler Lift Max LE110 SS Bale Forks and Frame Tractor Loader Attachment (A66734)
Unused 2022...
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
