Blueforester
- Joined
- Sep 25, 2003
- Messages
- 11
Couple of things here guys-
first off, shoot me your email, I have a PDF of the Tech manual you are welcome to for free
second, Deere just loves to put thin as water hydraulic oil in these front ends. They are nothing but big gear boxes, I worked in a dealer in the 90's and 2000's and when we had one like this we would, (with owners permission) put 145 wt gear oil in the front end. It is much thicker and would be a lot less prone to just pouring out like the water they use. You might still have a wet joint, but it just mighr be something you can live with for a lot less money. Just something to think about-
Good Luck
Joe
I want to say my manual called for J20D Hy-Guard and the dealer sold me the J20C saying that is all they use. Or vice-versa, I'll need to check. Not sure if this made a difference. I found this researching on-line where I guess in colder weather they were recommending removing the heavier weight oil and replacing w/ Hy-Guard in center section, but not the wheel hub. Not the same axle but I still thought it was interesting.
Mechanical Front Wheel Drive (MFWD) axle performance in cold weather
Blue
