John Deere 4120 & 48 Backhoe
   / John Deere 4120 & 48 Backhoe #11
Even on a cart there must be something that the landing gear pads could push on. Even a short section of 6x6 block under each side.....
I had same issue of 3point lifting 375 backhoe just short of being able to get pins in place. Bought 2 short sleeves that slip over my 3point pins and give just enough extra lift. Think the sleeves are for converting to the next higher 3point class. I have 3520 cab tractor. Pretty sure you can't use stabilizer until hydraulics hooked to tractor - have to be very close to in place to do that.
Thank you.
I used two Cat 1 to Cat 2 center link bushings. That worked fine.
   / John Deere 4120 & 48 Backhoe #13
I had the same issue with my JD 4600 with the 48 backhoe.
Adjusting the rockshaft feedback arm was easy to do and fixed the issue, once I figured out what to do...
2013 FORD F-350 (INOPERABLE) (A58214)
2013 FORD F-350...
2015 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2015 DRAGON 130...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
2193 (A58376)
2193 (A58376)
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
LayMor Sweepmaster 300 8HC (A55314)
LayMor Sweepmaster...
