john deere 4110 not charging
   / john deere 4110 not charging #1
collin1450
ieski
i have a john deere lv4110. serial number lv4110g112091. its not charging the battery. just had the alternator rebuilt. its the 55amp alternator not the skinny smaller alternator. the battery light is not coming on, bulb is good. iv swapped relays and made sure all fuses are good. im down to it being the voltage regulator but wanted to ask first, am i missing anything. thank you guys
   / john deere 4110 not charging #2
Welcome to TBN
Do you have the service tech manual for the 4110?
   / john deere 4110 not charging #3
Have you check outputs of alternator and voltage regulator with a meter? Like below has schematics, a few select test voltages. Click on the "Electrical Diag and Ops" illustration.
i read that post this morning. my diodes are there and plugged in. i ohmed out the diodes with my meter and they seem fine. both beep. battery connections are good. no power to the battery bulb in the dash. i believe thats connected to the voltage regulator
   / john deere 4110 not charging #5
am i missing something? the main lug on the alternator doesn't look connected to anything
that
thats how it was when i got it. power probe says its ground not voltage
i work on alot of tractors its not uncommon for the lug not to be used.
looks to me like this is the European design with the 55amp alternator not the 20 amp skinny alternator
   / john deere 4110 not charging #10
so they are pushing 55 amps through the voltage regular wiring? that looks to be 10-12 guage at most. I have not worked with external regulator's very often.
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2012 FORD F-150 XLT (A50854)
2012 FORD F-150...
1041 (A50459)
1041 (A50459)
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
