/ John Deere 4110 diagnosis #1
SunnyValley
4110 JD
Hi all,
I just purchased a new to me 4110 with just over 300 hours. It clearly needed a bit of work, but it was the only useful tractor in the budget since we bought land 4 years ago.
I was able to drive it on the trailer with some low power issues and puffs of black smoke. It would idle fine, but wasn't happy in gear. Wiggling wires on the fuel solenoid would shut it down, so my hopes were that it would be an easy fix. I replaced the solenoid and the smoke cleared up. The tractor would idle perfectly now without any smoke. Loader worked great in neutral.
The new issue was that the solenoid would kick the engine off in gear or when the pto was engaged. "Click". I started checking the specs for all safety switches. The seat switch was reading 30ohms on a and b when seated. That is high, but it shouldn't tell the fuel solenoid to shut down when the rear pto is engaged, as you are able to run that while off seat, I think? (Haven't been able to try yet)
I decided to do some regular maintenance. The old tractor was filthy from the brine and slush soaked drive home. Oil was overfilled, trans oil was overflowing out of the dipstick tube, and there was likely a 1/4 cup of sand and dirt in the gas tank, along with a bit of water. I drained and cleaned the tank, replaced the fuel filter, cleaned the housing, and blew out return lines. Put a new air filter in while I was at at. Added a splash of seafoam to fresh diesel and let it idle for 20 minutes. No issues. It idles fantastic. I go to start it in the morning.... strong crank, no start. Black smoke when trying to crank. I decided to check the battery. Charged it up and ran two test cycles with my battery repair charger. Green light there. Im feeling like there are electrical gremlins at this point, so I pull the computer under the seat and inspect the board. No hot spots, no cracked solder. Looks fine. Next I check grounds. Sure enough, the battery negative to frame is hanging on by a thread.... literally. Gentle wiggle snaps it right off. I got it! No.... brand new cable. Cleaned connections. Still won't start. Now I'm circling back to the solenoid. It's new, but is it working? 32ohms on terminals that should be at 12.4. That isn't good, but would it cause no start condition?
I am about to bypass the seat switch just to rule it out. New JD fuel solenoid inbound. I will update when I make some progress.
Any advice would be appreciated.
Thanks for reading,
James
/ John Deere 4110 diagnosis #2
It sounds like you are well versed in mechanical troubleshooting. I believe you are on the right track with the seat switch as an additional problem.
/ John Deere 4110 diagnosis #3
seat switch should be tied to pto switch.
Sounds like a lot of poor maintenance for a low hour unit
/ John Deere 4110 diagnosis #4
Any thoughts on how the engine oil and hydraulic oil become over filled? Was there any water in there? I'd keep a close eye on both to see if they continue to rise, which they will unless everything was the result of vandalism.
2001 John Deere 1760NT Planter (A63109)
2001 John Deere...
New/Unused SD Lanch SDLGC100 6-Seater Electric Golf Cart (A61166)
New/Unused SD...
Single Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A61567)
Single Cylinder...
2022 Ford F-150 Pickup Truck, VIN # 1FTMF1CB1NKE47600 (A61165)
2022 Ford F-150...
2018 CATERPILLAR 305.5E2 CR EXCAVATOR (A62129)
2018 CATERPILLAR...
Ratchet Straps (A61569)
Ratchet Straps...
