Backhoe John Deere 410B Hydraulic problem
   / John Deere 410B Hydraulic problem #1
JLazyA
John Deere 410B
I have a John deere 410b hoe with a hydraulic problem. It bareley moves when cold, as it warms up it moves faster. Anything hydraulic, steering, lifting, or hoe. We have changed the screen in the transmission, checked the line to the pump, and rebuilt the pump. And it is still the same. I think it is the priority valve but not sure what to check next.
   / John Deere 410B Hydraulic problem #2
First thing I would do is check trans pump psi & flow. PSI should be around 165-175 and flow 5 gpm. Usually it's the other way around. Works good when oil is cold and quits when oil gets warmer.
   / John Deere 410B Hydraulic problem #3
How do you check the PSI and flow??
Wooden
Where can I buy a gauge to start checking where the pressure isn't going???
2014 Chevrolet Cruze Sedan (A50324)
2014 Chevrolet...
2016 Ford Escape 4WD SUV (A50324)
2016 Ford Escape...
2012 Ford F-150 Pickup Truck (A50323)
2012 Ford F-150...
2019 Ford F-150 XL (A50120)
2019 Ford F-150 XL...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A52577)
1993 INTERNATIONAL...
2014 Nissan Maxima Sedan (A50324)
2014 Nissan Maxima...
