John Deere 410B drive problem
   / John Deere 410B drive problem #1
ML33567
Florida
John Deere 410B
Hi guys. I have an 84 JD 410B. The problem I am having is that it wants to pull forward in forward and neutral and there is no reverse. I have found some bad linkage that controls the flow to the convertor on the control valve to the reverser. I replaced the broken parts and still have the same problem. When I have the floor boards out and can see the drive shaft it will drive in forward or neutral and will stop turning when I go into reverse but there is no power to go into reverse and turn the wheels. It will turn the wheels in forward or neutral. I pulled the control valve off and the gasket was in good shape and there was no visible scarring in either of the spool valves but I didnt remove them from the housing. I am leaning toward there being some sort of problem in the reverser but dont want to go into that if someone here knows something else I should check first. I do have ALL the books on this tractor. Any ideas? Thanks
   / John Deere 410B drive problem #2
Since you have the books, I ASSUME Tech Manual, see if it has pressure tests for the reverse.
I am guessing leaking reverse lines or clutch.
Thank you for your response. I found the problem. The forward clutch pack in the reverser has failed and it drives in forward whether in neutral or forward. It stops driving when I go to reverse because the reverse is working fine.
Well I was wrong. I found the problem in the brake pedal control valve. The middle pedal was hanging up and had something to do with the reverse. I freed up the pedal so it would go to the top of its travel and now have forward and reverse. Heck of a lot easier than rebuilding the reverser and cheaper too. I have been using it for a week now and it works great.
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52128)
2017 Ram 5500...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2016 FREIGHTLINER M2 REFRIGERATED BOX TRUCK (A51222)
2016 FREIGHTLINER...
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A51222)
2013 FREIGHTLINER...
