Backhoe John Deere 410 Backhoe will not move and no Hydraulic
   / John Deere 410 Backhoe will not move and no Hydraulic #1
oldmanted
John Deere 410 Back Hoe
I need help I have a 410 Backhoe when I was digging I lost all Hydraulics and will not move but motor still runs. What do you think?
   / John Deere 410 Backhoe will not move and no Hydraulic #2
oldted
Time to get some hyd. pressure checks to see what/where the problem lies.
Make up a coupler with pressure gauge that can be connected at the quick coupling spots as a place to start.
Let us know..
oldted
Let us know..
Hi all I wonder if someone can help me. I was using my 410 and then I lost my hydraulics and could not move but the motor still runs. I let it sit for one year and started it up and all worked I drove it to a parking place and shut it off. I started it up again and no hydraulics and would not move. I had a John Deere field man come out and he said that it is my clutch. He said that I have to split it in two to fix it. Does that sound right?
Thanks
Thanks
   / John Deere 410 Backhoe will not move and no Hydraulic #5
Welcome to TBN
I agree 410 has a clutch that might have failed stopping input shaft from turning & trans pump from pumping oil. I saw no inspection cover in clutch housing to determine if clutch disk failed so I think I would remove trans top cover prior to splitting tractor to determine if trans gears/shaft won't turn when engine crankshaft turns.
Has hyd oil sump screen been checked/cleaned lately???
Welcome to TBN
Thanks for the info I will check screen first.
Thanks for the info I will check the screen first.
   / John Deere 410 Backhoe will not move and no Hydraulic #8
Please don't do duplicate posts or start new threads when they fit in your old thread. tks..
:welcome: to TBN
do you have instructions on how to use this site?
The screen was clean so I split the Backhoe from the motor to check the clutch and found that it is OK. I guess I have to go too the oil pump next, I think that it is in the trans housing. Do I have to split the bell housing from the trans housing to get to the pump?
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
MAH QUICK ATTACH MAST W/ 48" FORKS (A51242)
MAH QUICK ATTACH...
2016 Ford Fusion Passenger Car, VIN # 3FA6P0G79GR191653 (A50324)
2016 Ford Fusion...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2018 WACKER NEUSON RD28 120 DOUBLE DRUM ROLLER (A51242)
2018 WACKER NEUSON...
2018 HINO 258 SERVICE TRUCK (A51243)
2018 HINO 258...
