Backhoe John Deere 410 Backhoe will not move and no Hydraulic
   / John Deere 410 Backhoe will not move and no Hydraulic #1
oldmanted
John Deere 410 Back Hoe
I need help I have a 410 Backhoe when I was digging I lost all Hydraulics and will not move but motor still runs. What do you think?
   / John Deere 410 Backhoe will not move and no Hydraulic #2
oldted
Time to get some hyd. pressure checks to see what/where the problem lies.
Make up a coupler with pressure gauge that can be connected at the quick coupling spots as a place to start.
Let us know..
oldted
Let us know..
Hi all I wonder if someone can help me. I was using my 410 and then I lost my hydraulics and could not move but the motor still runs. I let it sit for one year and started it up and all worked I drove it to a parking place and shut it off. I started it up again and no hydraulics and would not move. I had a John Deere field man come out and he said that it is my clutch. He said that I have to split it in two to fix it. Does that sound right?
   / John Deere 410 Backhoe will not move and no Hydraulic #5
Welcome to TBN
I agree 410 has a clutch that might have failed stopping input shaft from turning & trans pump from pumping oil. I saw no inspection cover in clutch housing to determine if clutch disk failed so I think I would remove trans top cover prior to splitting tractor to determine if trans gears/shaft won't turn when engine crankshaft turns.
Has hyd oil sump screen been checked/cleaned lately???
Welcome to TBN
Thanks for the info I will check screen first.
Thanks for the info I will check the screen first.
   / John Deere 410 Backhoe will not move and no Hydraulic #8
Please don't do duplicate posts or start new threads when they fit in your old thread. tks..
:welcome: to TBN
do you have instructions on how to use this site?
The screen was clean so I split the Backhoe from the motor to check the clutch and found that it is OK. I guess I have to go too the oil pump next, I think that it is in the trans housing. Do I have to split the bell housing from the trans housing to get to the pump?
2011 IC Corporation PB105 School Bus (A49461)
2011 IC...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2020 KUBOTA RTV...
5K BLOWOUT PREVENTER (A50854)
5K BLOWOUT...
