Dirt Moving john deere 401a hydraulic question
   / john deere 401a hydraulic question #1
junkman 1975
forest city,mo
kubota 3130
i was told it will burn up my hydraulic pump using my loader on my backhoe tractor with the clutch pushed in due to the pump in the shuttle shift transmission being disconnected and not pumping oil to the front pump.
i dont see john deere doing something but would like to know for sure .
is a factory front loader and backhoe tractor ind model. thanks lance
   / john deere 401a hydraulic question #2
I don't know if it would burn up, there is an reservior to supply it when the trans pump is not running, but it's limited capacity. Loader would not have oil flow to move for very long.
is it good enough to load a truck or unload a hay bale from a trailer without doing any damage to the pump do you think use the shuttle shift and not use the clutch as much
   / john deere 401a hydraulic question #4
Most operators I've witnessed using a tractor with a reverser just leave clutch pedal up and use reverser to control tractor movement That's the concept of a reverser no need to depress clutch to change directions of travel. IIRC the reverser has a neutral area.
2025 ZJG ZJ-13 Mini Excavator (A56857)
2025 ZJG ZJ-13...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2 Disc Heavy Duty Bottom Plow (A57454)
2 Disc Heavy Duty...
Pemberton 8' Rake (A57148)
Pemberton 8' Rake...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
JOHN DEERE 9570 RX (A58216)
JOHN DEERE 9570 RX...
