John Deere 4010
/ John Deere 4010 #1
clem754
tampa, fl.
john deere/4010
My front loader and my 3 point hitch will not lift as heavy a load as it used to; I hear a strain like a clutch slipping, etc. Any ideas as what to check? This
is my first tractor and this one has really saved my back, as I am older than dirt. Thanks.
/ John Deere 4010 #3
4010 CUT(14 pto HP) or 4010 RC(80 pto HP)? 2 totally different machines.
/ John Deere 4010
Brrr. it must be cold up yonder. Keep warm my friend.
/ John Deere 4010
CUT; I sent a reply but not sure if it went...thanks
/ John Deere 4010
On my CUT, front loader won't life a load as high as it used to and my boom on the rear won't lift the same weight that it used to. thanks
/ John Deere 4010 #7
If your hearing a "whine" it could be that your hydraulic system is restricted. This could be caused by ;
A clogged or restricted hydraulic filter
Worn fluid
Worn hydraulic pump
A loader control valve is not opening all the way
Or other causes. This is my personal opinion but how do you know your loader won't lift the amount of weight it used to? What do you normally lift? Hay bales, dirt? Engines ?
/ John Deere 4010 #8
Worn fluid
How does diagnose that there fluid is "worn"? That's a new one that I've never heard of.
/ John Deere 4010 #9
How long since hyd filter was changed?? I would also suggest to take a hyd pressure reading.
/ John Deere 4010 #10
Pretty good suggestions. On my 4010, it seemed to have an internal bypass on the hydraulics that seemed to pop pretty easily. I'd sometimes have to back away a bit to get the FEL to go up or to curl. It was pretty strong though. First job for it was the hauling of 22 tons of gravel. It'd carry the FEL completely full of gravel. Trick was in how you got it filled.
Ralph
/ John Deere 4010
I had previously lifted this same engine a foot off the ground with my boom to place on a stand. I tried to lift it off of the stand and it began whining, so I let it back down.
/ John Deere 4010
Thanks; I'll check those things.
Hyster 50 5,000lb Propane Forklift (A64553)
Hyster 50 5,000lb...
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
Kubota L2501D 4x4 Utility Tractor with Land Pride 72in Brush Cutter (A64553)
Kubota L2501D 4x4...
2006 Stephens Aluminum 407 T/A Chemical Tanker Trailer (A64194)
2006 Stephens...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
