John Deere 4010 or Kubota B7500
   / John Deere 4010 or Kubota B7500 #11
have u taken them out for test drives? if not , do so. and then buy the one that fits U best.
   / John Deere 4010 or Kubota B7500 #12
Excellent adivce, just wanted to toss in the 4100 is listed in my specs as having 20 gross horsepower and 17 PTO and the 7500 is listed at 16 horse. I think the new 4010 is like 14 or something so I would still think the better comparison to be the 4100 or 4110, could be wrong.
j
   / John Deere 4010 or Kubota B7500 #13
The 4010 has 18.5 gross horsepower and the B7500 has 21 gross horsepower.
   / John Deere 4010 or Kubota B7500 #14
the gear versions [of the jd 4100] are 1hp more at the pto than the hst versions.
   / John Deere 4010 or Kubota B7500 #15
I bought the B7500 with the 302 FL on 3-16, I drove the J.D. 4010 and the Kubota B7500. The things I did not like about the JD was the Throttle being on the side of the hood and not on the steering colum, the forward and reverse pedals being side-by-side (I thought I could accidentially hit the wrong pedal in close quarters) the seat belt did not retract, less horsepower, less cooling and oil capacity, less hydraulic oil capactiy, and the JD dealer could not get this tractor until May 1. There are some things I did not like about the B7500 but overall I think I got more for my money buying the Kubota. I hope to get the B7500 by the end of the week - I can't wait.
   / John Deere 4010 or Kubota B7500 #16
Congrats on going with the B7500. Make sure you post some pics of it once you get it (you'll need to register to do that /w3tcompact/icons/wink.gif).
   / John Deere 4010 or Kubota B7500 #18
As I've pointed out many times (maybe too many /w3tcompact/icons/blush.gif), you probably don't want to put too much stock in the horsepower claims, as the HP curves can vary so widely, and also differ in terms of continuous and/or intermittent HP availability (not to mention whether the HP is what you expect at PTO RPM as an example). You're much better off comparing the displacement of the engines, and looking at the torque curves for the engines (which will follow the displacement very closely).
I haven't found any detailed information on the Deere units that have been discussed here, but if I were comparing these machines for available power, that is the method I would choose.
BTW - Fine choice. Of course I wouldn't be prejudiced.... /w3tcompact/icons/wink.gif
   / John Deere 4010 or Kubota B7500 #19
Congrats, I know you will enjoy the tractor, it has done everything asked of her never lacked for power.
Have fun and be safe.
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
Kent KHB3G Q.A Hydraulic Breaker (A50121)
Kent KHB3G Q.A...
Electric Mobility Scooter (A51694)
Electric Mobility...
2013 John Deere 469 (A50120)
2013 John Deere...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
