john deere 40
   / john deere 40 #1
mwalkerd
i have a john deere 40 i bought that looks great but clutch is making noise unless i depress clutch, then noise goes away. does anyone have any experiance in rebuilding the clutch in a classic tractor like this??
thanks
monty in nebraska
   / john deere 40 #2
I don't have experience with the 40. But a normal situation I would say the throw out bearing is bad. Are you talking about a two cylinder 40?
   / john deere 40
yes an old 1954 jd 40 - i'm an oil, and gas ONLY kinda guy, but i can follow a manual. does a repair book exist to fix clutch issue
   / john deere 40 #4
The books are out there. Try Jensales. The pilot and throwout bearings probably need replacing. Do both while you have the tractor split. I replaced both on my 420 crawler which is almost an identicle setup to yours. For a few more dollars you may want to have the flywheel turned flat and replace the clutch. You dont want to split the tractor twice, unless of course you like to!
   / john deere 40 #5
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A50397)
John Deere 6105E...
Morooka MST 660VD Tracked Dump Truck (A50397)
Morooka MST 660VD...
New/Unused 20ft Farm Iron Gate (A48837)
New/Unused 20ft...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2006 Land Rover Range Rover Sport 4x4 SUV (A48082)
2006 Land Rover...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
