John Deere 350B dozer track roller question
   / John Deere 350B dozer track roller question #1
eddie48
McDonough, NY
TC45DA, TC40DA, Farmall Super A, New Idea spreader, Dolmar and Echo saws, Yanmar MIniEx, Ford 3550 backhoe, lots of junk
I recently got a 350B which seems to be in excellent shape. Starts, Runs and everything works. Undercarriage seems tight and all is well. However, I would like to be sure that the rollers on the track are properly lubed. The book talks about the button grease fittings but when I tried to grease it, I found that, on one side of the machine all of the roller bearings seem to have been replaced with sealed bearings. Just a smooth surface with no place for a grease fitting. On the other side there there are nuts with what looks like a half of a button fitting in the center. The half buttons are tightened with an allen wrench. If I remove this fitting, I find that it is not a fitting at all, but a plug. Taking it out of the end of the roller, I find that it seems to have 90 wt gear lube on it, not grease.
Am I missing something? Do I add gear lube to it? How and how much? Should I replace the plugs with grease fittings and grease?
   / John Deere 350B dozer track roller question #2
Generally, they have 90W in them, and you run them until they need service. (read leak)
No leaks, then leave them alone...
SR
Thanks. I'll do just that.
Ed
   / John Deere 350B dozer track roller question #4
90-w and they call them lifetime lube but I keep mine full to the level of the plug cause they are starting to leak!
1992 Ford E350 Box Truck (A53117)
1992 Ford E350 Box...
2018 Mack PINNACLE CXU613 Sleeper Truck Tractor (A53117)
2018 Mack PINNACLE...
John Deere GR72B (A50123)
John Deere GR72B...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
2021 Honda 520 Foreman, 4WD  (A52384)
2021 Honda 520...
2017 Dodge Journey SUV (A51694)
2017 Dodge Journey...
