John Deere 350 sickle mower
   / John Deere 350 sickle mower #1
bledsoe73
Miami, Ok
Ford 7700
I have a john deere 350 9' sickle mower and I put a new belt on it. The is loose and I need to know how to ajust it. Also the spring that levels the blade when the blade is down it will not lay flat on the graund the end is up about 4" how can this be ajusted down ? Any help would be appreciated. Thanks.
*the belt is loose
   / John Deere 350 sickle mower #3
You should be able to adjust the float of the blade and get it to lay down flatter by adding links in the chain that runs thru the middle of the cutterbar spring. Lift-raise the cutterbar up to take the tension off the spring and then add links.
Did you have to move the pulley to get the old belt off?
AKfish
   / John Deere 350 sickle mower #4
There is a bolt for adjusting belt tension. It is located at the left and low. A owners manual would be a good investment. Ken Sweet
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
2025 New/Unused Wolverine 3 Point Quick Hitch (A51573)
2025 New/Unused...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2020 INTERNATIONAL...
New/Unused AGT Industrial SDA-140T Track Loader (A51573)
New/Unused AGT...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
