John Deere 350 sickle mower
   / John Deere 350 sickle mower #1
KThurman
John Deere 5105
I am trying to find rock guards for my 350 with snap in ledger plates. Deere keeps sending guards with the riveted style plates. These are two completely different parts. Anyone had a problem like this or a good suggestion. Thanks
   / John Deere 350 sickle mower #2
Is this the part # the dealer is selling you???
Part Number: AE36136
Part Price: 13.75 USD
Description: GUARD, SNAP-IN
Specification
Weight 1.61 LBS 0.73 Kg
Length 6.700 IN
Bolt Size 0.488 IN
Slot Width 0.122 IN
Slot Depth 2.160 IN
Offset 0.365 IN
Offset Depth 0.760 IN
Yes thats the part numbering he is ordering. The part we are getting has that number on it but- it is wrong.
   / John Deere 350 sickle mower #4
Back when I worked for a JD dealer the parts person contacted the JD branch house and found out what the problem is. That may not happen with today's parts people and the different thinking CEO's @ JD.
My dealer got a case number on this and had been working on it for a few weeks. I have since resolved the problem after talking to a guy at sickleservice.com. He has the replcement guards # G-220. They are doubles and are the throw away type ( ledger plates made in ) and swears they work better with less clogging and can also be used with the singles and are about half what I would have paid at Deere. I will let you know how everything works when I get the parts.
   / John Deere 350 sickle mower #6
I use a 350 that I set up entirely with the forged double guards. It works great, never bend a guard or any other problem. As far as I'm concerned the old type guards are obsolete.
By the way, they may be "throw away" type, but I've never yet had to replace one on any of my sickle bar mowers.
   / John Deere 350 sickle mower #7
Those jd snap in guards are not worth the money. To thick in the nose and rough to boot. I had to rework the nose with an angle grinder. Always seemed to have one or two that the ledger plate never set right. Finally got another set of old guards at an auction and a guard service anvil. Have two sets and rebuild them on nasty days. With the anvil it's a quick easy job and the guards are much thinner and better shaped. The integral double guards work well with serrated sections but I like smooth sections and replaceable ledgers cause I'm frugal. I do have tiger jaw sections on the outside/inde by the shoes with the corresponding open guard because the eliminate 95% of the plugs. I sharpen/change knifed every 4 hours and resharpen both at the end of the day. A johnsons sickle servicer makes knife maintenance a pleasure.
   / John Deere 350 sickle mower #8
recently bought jd 350 mower with broken cutter bar, i ordered from john deere dealer new bar @ 185.00 problem now is it doesn't touch or there is too much gap between cutter and teeth. it seems to have mutiple types of teeth not oem i think. does anyone know a source to replace them with all new teeth or a rebuild kit that would include all new teeth. since i have the new cutter bar all i need are the teeth. thanks joe.
2009 Freightliner Columbia 120 Winch Truck, VIN # 1FUBA5CK39DAM2731 (A51572)
2009 Freightliner...
(4) Drums of Mixed Fabric Softener/Detergent (A51573)
(4) Drums of Mixed...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
JOHN DEERE 2038R LOT NUMBER 175 (A53084)
JOHN DEERE 2038R...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
