John Deere 345 Time Delay module
   / John Deere 345 Time Delay module #1
Pacat
John Deere 345 Time Delay module, Can it be bypassed (jumped)?
I got a JD 345 with the symptoms, crank but no spark. From what I been reading on other post this is a very common problem that is caused by the Time Delay Module. I will pick up the part #AM128906 module first thing Monday. While I'm waiting is there a way to bypass or jump out the module to see if it's the problem and if so what wires do I jump? Would like to be able to try this before spending the $20 for the module.
   / John Deere 345 Time Delay module #2
Re: John Deere 345 Time Delay module, Can it be bypassed (jumped)?
Are you sure that you have this module on your particular 345? They don't all have them ----
The FD590V engines don't have this module --- the FD611V engines do. So, from memory here, I think your serial number needs to be above 070000 for you to have this module on your engine.
Yes I have it, on the left side of the engine, below the fuel filter. I would like to test it before I spend the money on a new one.
   / John Deere 345 Time Delay module #4
Sorry, can't help with a test for that module. The tech manual for that model should describe how to test it. I don't have that manual -- guessing you don't have it either. At $20 or so, most just replace it.
Update: I bought a new Time Delay Module, installed it and hit the key. The tractor started up! A quick and easy fix. The parts guy at the dealer said 95% of the time that when there is no spark at both plugs this is the problem. Thanks for the help.
   / John Deere 345 Time Delay module #6
Thanks for the update --- a lot of the time, we never do get the final resolution. Nice to get it and Congrats.
   / John Deere 345 Time Delay module #7
I have an early 345 with out it. Sometimes when I start it it only runs on one cylinder. Since I do not have the module, Any idea what the problem could be? I have heard or read that it may the plastic cam gear. What about the ignition module? Thank you.
Gene
   / John Deere 345 Time Delay module #8
Gene
OK this is a little confusing. Does it always run on just one cylinder? Or do both of them work after the engine is started?
Have you checked compression?
Richard
   / John Deere 345 Time Delay module #9
Richard
No, I have not checked compression. I go out and sometimes I start it and it starts right no problems at all and runs great all day. Start and stop no worries. Other times I go out and it does start up on BUT it is only running on the right #2 cylinder. Now, I did have an issue this spring in which my battery light was flickering on and off. I checked everything I could and found the starter was shorting out internally. I took the starter out and tore it down completely. It was packed with dust and crap. I put it all back together and it worked great. When I was putting it back, I did somehow, put pressure on the igintor box and it broke off one of the corners. I sealed it back up with silicone and it has been fine. In the past 6 weeks, it has started doing what I explained. Starting but only running on one cylinder. Having not worked on it for a while, I did forget about the crack or broken corner on the ignitor. It only broke the plastic housing and not the internals.
I am guessing at this point the ignitor has crapped out. What do you think.
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
17307 (A55853)
17307 (A55853)
Sedan (A59231)
Sedan (A59231)
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
*Selling at Royal Auction Zephyrhills, FL Location* Year: 2005 Make: Mitsubishi Fuso Model: FE84D (A59230)
*Selling at Royal...
