John Deere 345 dies out and needs choke to restart
   / John Deere 345 dies out and needs choke to restart #1
sparky672
Manhattan, IL
John Deere 345
John Deere 345 (1998) with a Kawasaki FD590V engine (800 hours)
I am the original owner and have always maintained this tractor as per the standard maintenance schedule.
I'm having an intermittent issue and I need to know how to conclusively check whether I have a bad carburetor, or something else like a weak fuel pump.
During mowing only, whether the tractor is under load or not, it sputters out and dies. Then it takes constant choking to get it started again. It has to run a bit while choked before it stays running. Then it runs normal for a few minutes and then dies again. It's like the fuel is temporarily shut off somehow and it only runs until the fuel in the bowl is consumed.
I've had the carb apart and it always seems to run better after this, but within a couple hours the problem returns. There is a new air filter, carb gaskets, fuel filter is not clogged, and there seems to be adequate fuel pressure and flow. The carb has been cleaned and the float adjusted to factory spec; and it runs great in the garage. I've adjusted the throttle and choke plate to factory spec. I only have this issue while mowing but it's not related to load. I can bog in down in thick grass and it runs fine... then later in easy grass, it just sputters out.
I also have a possibly related issue where I cannot shut off the tractor without popping and backfiring. I can't even throttle it down without backfiring. Even if I throttle down very slowly, I still get backfiring and popping.
This video shows the problem as it's happening. You can see how I need to keep choking it before it stays running. Then I can resume cutting for a minutes longer.
https://youtu.be/dljnTozdBMc
I need suggestions and advice before throwing any parts at it. I'm thinking it needs a new carb but not sure... maybe fuel pump?
Thank-you for any suggestions!
   / John Deere 345 dies out and needs choke to restart #2
Try back blowing the line from the fuel filter to the fuel tank. Something is plugging the fuel pickup in my JD 285 and that works for several months for me. I am not wanting to pull and clean the fuel tank (looks like too much work to remove the fuel tank)
I'm definitely going to take your suggestion. However, I failed to mention that this only seems to be happening when it's warm. Whenever I try fixing it and test mow at night, the problem never happens. In either case, it could still be an issue related to fuel flow, so your idea is solid. Thanks.
   / John Deere 345 dies out and needs choke to restart #4
Maybe vapor lock? Is there a way to insulate the fuel lines?
Yes, it's possible. However, the lines are in their stock configuration. All stock heat shields are in place. Nothing has been modified since the tractor was manufactured.
So if it's vapor lock, I'd like to find what's broken, rather than making any modifications.
   / John Deere 345 dies out and needs choke to restart #6
i had same problem with my jd345,i cant give you any solution because i got tire of it and traded the tractor. i did everything you did then asked the dealer they said change fuel pump so it did that and it didnt fix problem. could it be electrical?
...could it be electrical?
I don't understand how it could. The fuel delivery system is 100% mechanical, and it always restarts after some choking. I've also found that choking when it starts sputtering keeps it from dying.
   / John Deere 345 dies out and needs choke to restart #8
If it's got one them anti-backfire solenoids, then look at that. I had one on a B&S that I finally ground the tip off the valve part and then no more problems. bjr
This model does not have that.
   / John Deere 345 dies out and needs choke to restart #10
Did you ever resolve this issue? I am having what seems to be the same problem. At first I thought it was just the fuel pump because I did see it leaking when I could get it running. I changed the pump and mowed for several hours. I suddenly stopped and I found that the only way to start it was to push the choke lever forward and even at that I had to nurse it back to the garage. I was beginning to wonder if I got a bad pump.
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A52576)
2013 FREIGHTLINER...
2021 KUBOTA SVL75-2 SKID STEER (A51246)
2021 KUBOTA...
LMC G500-500A LOT NUMBER 233 (A53084)
LMC G500-500A LOT...
JOHN DEERE 7210R LOT NUMBER 252 (A53084)
JOHN DEERE 7210R...
THE HANDLER II MIXER UNIT (A52472)
THE HANDLER II...
