John Deere 345 blade clutch issue
   / John Deere 345 blade clutch issue #1
scollins
Rolla, ND
John deere 2305, X520 and LX188
I'm working on a John Deere model 345 with 500 hours on it for our church. The mower has worked flawlessly for years but recently the bolt that holds the blade clutch to the crank shaft broke. Replaced it with new bolt from dealer. Broke again within about an hour of mowing. Replaced with bolt from dealer. Broke after an hour. Replaced with bolt on half inch longer. Broke within five minutes. HELP.
Clutch appears to work properly both on the mower and off.
   / John Deere 345 blade clutch issue #2
:welcome:
I'm not understanding the terminology you are using to describe the problem. But hopefully there are others who will be able to figure it out.
Is this the clutch? And is it the bolt shown? And only one bolt holding that clutch?
   / John Deere 345 blade clutch issue #3
Welcome to TBN.:)
I think you are "fixing" the symptom rather than the problem. If the bolt is shearing off, it must be from too much torque to start the mower deck. I would remove the mower deck and closely inspect all spindles and pulleys to look for binding. There might also be something rubbing against the belt that is adding additional force, but normally that would be accompanied with smoke and odor. I'd bet that if/when you get the mower deck "tuned up" the problem will go away.
Yes this is the clutch I'm talking about and yes it is the bolt that goes through the assembly and into the crank shaft.
:welcome:
Yes this is the clutch and yes that is the bolt.
   / John Deere 345 blade clutch issue #6
The deck's torque load should be driven by the key (inside the clutch) against the keyway in the motor crankshaft.
Have you checked the condition of the key & keyway?
Is the clutch pulley bent, warped or otherwise damaged?
Are you tightening the new bolts to the specified torque?
Good luck?
John
   / John Deere 345 blade clutch issue #7
Good luck?
John
I think you may be onto something John.:thumbsup: If the key was lost when the clutch first came off or it is a shear type key, it is probably completely missing.
   / John Deere 345 blade clutch issue #8
I don't think it is a seperate key. The JD clutches I have seen had the key cast into the ID of the clutch assembly.
   / John Deere 345 blade clutch issue #9
G'day i think you are spot on and the bolt is prob trying to take the load rather than a key is the clutch a nice neat fit onto the shaft or is there a bit of movement, may have flogged the centre out of the clutch if this is the case you are never going to keep it tight you may need a new clutch:(
Jon
   / John Deere 345 blade clutch issue #10
I have a GT242 and the last clutch that put in required a piece of 1/4" key stock. So it could be that the key is missing.
18009 (A51691)
18009 (A51691)
2020 CATERPILLAR 242D3 WHEELED SKID STEER (A51242)
2020 CATERPILLAR...
Pull-Behind Smooth Drum Ballast Roller (A51691)
Pull-Behind Smooth...
Barn Wood Picnic Table (A50515)
Barn Wood Picnic...
2 Wheel Wagon / Cart (A50515)
2 Wheel Wagon /...
Wolverine Mini Skid Steer Pallet Forks (A50514)
Wolverine Mini...
