John Deere 336 with #30 Bale Ejector Problem
   / John Deere 336 with #30 Bale Ejector Problem #1
sgm98z
Orrstown, PA
Massey Ferguson 255
I have a Massey 255 and a John Deere 336 with a #30 bale ejector.
The Massey has a set of remotes that are normally used for the FEL which works fine.
When I hook up the baler to the remotes I can only get the ejector to turn in one direction. In order to get it to turn the other way I have to reverse the hydraulic lines. I'm wondering if this is a problem with the baler or the tractor?
The reason I'm confused is that the FEL works just fine when connected to the remotes.
Any ideas how to isolate the issue?
   / John Deere 336 with #30 Bale Ejector Problem #2
Does the FEL have its own control valve.... I expect so.
Some rear remotes are intended for double acting cylinders and either half of the remote can become an IN or an OUT port.
I do not know your tractor and what control you have over the rear remotes.
It may be that if you cannot change your remote's IN and OUT, that you need a double acting valve in order to control the baler.
Then the hook up will be like your loader.
Dave M7040
Dave M7040
Dave, thanks for the reply. I think you may have nailed it. The FEL does have it's own control valve. I didn't think of that. I'll look into the double acting valve and see if that remedies the issue. Thanks again, Mark
2019 Kubota RTV-X1140 4x4 Utility Cart (A51691)
2019 Kubota...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
2012 Scion Xb SUV (A51694)
2012 Scion Xb SUV...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
JD 1814E LOT IDENTIFIER 264 (A53084)
JD 1814E LOT...
