John deere 335 with a 20 h. p. kawasaki engine
   / John deere 335 with a 20 h. p. kawasaki engine #1
chevyflan
john deere gp
After key is turned off takes another 10 seconds for motor to shut down. AT times it starts hard too both coils have been replaced plugs fuel filter and valves have been set also new ignition and ignition box that is hooked on to ignition is new .
   / John deere 335 with a 20 h. p. kawasaki engine #2
Correct me if I'm wrong but I think these engines have a fuel shut off solenoid. I would take it out and make sure the pin inside moves freely. It almost sounds like it's rusty or is not in good shape electrically. Sorry I don't know the specs for the solenoid coil.
   / John deere 335 with a 20 h. p. kawasaki engine #3
Do you mean that the engine "runs on" and coughs and sputters before shutting down?? As the previous poster indicates, does it have a fuel shut off solenoid?? If it does --- sounds like it could be a problem. If it doesn't, I would buy it a new carb.
2012 Buck Verano Sedan (A55758)
2012 Buck Verano...
2009 International 7400 T/A VacCon V311LHA Combination Sewer Jetter Vacuum Truck (A55788)
2009 International...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
3 - JACK STANDS (A55745)
3 - JACK STANDS...
2025 MAMMOTH SB-2 2025 SAND BOX TRAILER (A56129)
2025 MAMMOTH SB-2...
2017 John Deere 855D 4x4 Gator Utility Cart (A55787)
2017 John Deere...
