John Deere 3320
/ John Deere 3320 #1
gaw59
John Deere 3320
Hello, I'm 73 and bought a JD3320 with loader and brush hog. Mostly to keep large lawn area trimmed and snow plowed. I'm from Michigan.
/ John Deere 3320
I have a 2009 JD3320 eHydro. The blinkers work, but the turn signals don't. The turn signals worked when I bought the tractor. Does anyone know if I could have done something to a setting that stopped them from working. Is the turn signal switch different from the blinker switch? Is there any video showing how to access the turn signal?
/ John Deere 3320 #3
You say the blinkers work but turn signals don't. What are the blinkers - the four way flashers? If so they may use two different flasher units. It's also possible you have a burned out bulb. I'm pretty sure the key must be on for turn signals to work but that may not be necessary for flasher operation.
/ John Deere 3320 #4
G'day Mate and welcome to TBN from Downunder.
If the blinkers (four way flashers) work but the turn signals don't then there is nothing wrong with the 'bulbs', flasher relay or capacitor circuit... that is off of your 'light switch'. The problem lies with the Left/Right turn signal switch or switch circuit. If both Left/Right indicators do not work then look for something common ie: a fuse or a loose wire.
Your local JD Dealership (Parts Dept) should be able to provide you, free of charge, a wiring diagram. (I know that my Dealership would do this)
Enjoy the site.
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
WATER TRAILER (A58214)
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
iDrive TDS-2010H...
WANCO LIGHT TOWER (A60736)
WANCO LIGHT TOWER...
