John Deere 332 Yanmar Diesel
   / John Deere 332 Yanmar Diesel #1
metro
Sarahsville Ohio
Ford 4000
Engine starts easily but after 15/20 minutes run time it begins to lose RPM's, starts smoking and eventually quits running.
Installed new inline fuel pump and 2 injectors. Same problem.
Open for repair ideas. Thanks
   / John Deere 332 Yanmar Diesel #2
:welcome: to TBN
Have you opened the fuel tank cap to see if there is a plugged vent? Try this the next time you detect it losing rpm's.
   / John Deere 332 Yanmar Diesel #3
:welcome: to TBN
That's where I would look first ---- I would also check for a plugged fuel filter.
   / John Deere 332 Yanmar Diesel #4
Reading a similar issue on another forum, it turned out to be the fuel filter plugging up from microbial growth in the fuel.
For example:
Bacteria in Diesel Fuel - Diesel Engine Problems - MyCleanDiesel.com
You might need to get a fuel system cleaner and a couple new filters. Add the cleaner, run it with a new filter, then change the filter again after a few tanks.
Here's the thread in another forum; page two has the pertinent info near the end of the thread:
http://www.****************.com/forums/sub-compact-utility-tractors-scut/19616-2305-misbehaving.html
HTH!
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
New/Unused 10ft Workbench with 15 Drawers (A51573)
New/Unused 10ft...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
