John Deere 325 Garden tractor - Battery Charging Light
   / John Deere 325 Garden tractor - Battery Charging Light #1
topsaiilbye
Ottawa, Ontario, Canada
John Deere 325
when i engage PTO with snowblower, battery charging light coming on. ok when PTO off.
replaced battery 3 Mos ago.
thoughts?
   / John Deere 325 Garden tractor - Battery Charging Light #2
Look at the charging circuit, what is the stator putting out? what is VR putting out? check your grounds, check wiring from VR back to battery, it may go through the key switch also. Plus check the PTO resistance in case that is having issues and drawing to much current. Most are around 4 ohms, anything less than 3.5 will starting draw to much current, don't get to worried till it is around 3 ohms.
   / John Deere 325 Garden tractor - Battery Charging Light #3
Nothing is wrong with the tractor.
The battery is partially discharged, causing the light to come on.
Recharge the battery, the light will stay off.
You may need to charge the battery several times, to get it perfect.
   / John Deere 325 Garden tractor - Battery Charging Light #4
topsaii
This happen while you are running at night with lights on? Also, have you added additional lights?
Do a load test on the battery after charging.. may be a bad battery in the end.
:welcome: to TBN
   / John Deere 325 Garden tractor - Battery Charging Light #5
Welcome to TBN. Good advice above. When you are covering bases and cleaning terminals, clean the pigtail at the regulator extra good. Verifying system voltage would be a great idea with and without the PTO engaged.
UNUSED JCT 72" HD VIBRATORY ROLLER (A51248)
UNUSED JCT 72" HD...
NEW HOLLAND TN75SE TRACTOR (A51247)
NEW HOLLAND TN75SE...
2021 JOHN DEERE 8R340 LOT NUMBER 209 (A53084)
2021 JOHN DEERE...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A53472)
2003 International...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
