John Deere 322 PTO Problem
   / John Deere 322 PTO Problem #1
yanmar3
I recently installed my #49 snow thrower on my John Deere 322 and the front PTO worked fine when testing it. I went to blow snow the other day and the PTO engaged briefly and then quit. I readjusted the air gaps to .018" and measured the coil resistance to 3.2 ohms and the voltage to the connector was 14.3 volts DC. When I flip the PTO switch I can hear a relay click, but it won't engage. I'm about ready to tear the PTO apart to find the problem, but am looking for any help or suggestions before I do so. Thank you.
   / John Deere 322 PTO Problem #2
:welcome:
At a loss to help you, but wonder about any safety switches that may not be set right.
Has anything shown up on a search of TBN?
   / John Deere 322 PTO Problem #3
It sounds like you have it under control! The only other thing I could sugggest is check the ground system and take your battery to a auto parts store for a load test. If your battery is weak the pto will not engage. My neighbor had a 212 that would not engage and it was the battery. It started fine, just would not engage the pto.
KUBOTA BX2350D TRACTOR (A51247)
KUBOTA BX2350D...
Peterbilt 377 Semi-Truck (A52748)
Peterbilt 377...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
CATALYST INJECTION TANK (A52472)
CATALYST INJECTION...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
