John Deere 3203 Spool Valve Question with Pics
   / John Deere 3203 Spool Valve Question with Pics #1
Emperor
Baton Rouge
John Deere 3203
Obviously, this adapter fitting is severely damaged and must be removed. The nut between the threading is corroded so badly that it will not accept a wrench, and it appears to be seriously corroded into to threading of the spool valve.
Does anyone have a suggestion on how I can turn that adapter fitting to see if I can get it out without breaking it off in the spool valve?
   / John Deere 3203 Spool Valve Question with Pics #2
Put some penetrating oil on it and let it sit a few days. Take a dremel ( or similar tool) with a rotary burr and grind the threads down on two sides to make wrenching flats.
Thanks! That may be a bit better than what I thought I might try, which was to drill a hole through the adapter, and stick a heavy nail (12D), through it to have it act as a lever so I could turn it.
   / John Deere 3203 Spool Valve Question with Pics #4
I'd try a pipe wrench, but soak it good for a few days. Depending on what you plan to do next with that valve, you could try heat on it.
Thanks to you both. Those suggestions gave me a moment of clarity!
I am performing this fix in the field. I probably have only one shot at getting that adapter out, because if that Spool Valve fails or I irreparably damage it, I may just scrap this machine. Once I got down to where I could see all the hydraulic fixtures under that seat, I started to ask myself; "Why would John Deere use such crappy metal connectors on these oil lines?" All are heavily rusted, and falling apart; and look like they will fail soon too. It's a tractor for heaven's sake! I will replace those too if this current step works out. But that is it! These things are money pits after 20 years!
Next tractor? Garage kept!
Deere 9965 Cotton Picker (A52748)
Deere 9965 Cotton...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
2014 Ram 5500 4x4 Altec 37G 37FT Bucket Truck (A50323)
2014 Ram 5500 4x4...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
74in FEL HD Round Back Bucket (A52748)
74in FEL HD Round...
