General Stuart
- Joined
- Dec 27, 2012
- Messages
- 31
- Location
- Knoxville, Tennessee
- Tractor
- 1983 John Deere 318 & a 1986 John Deere 130
I hope the problem isn't a bad starter on your deere cause I believe you have to remove the engine to replace the starter on the 318
Hello
Pulling the Engine is Not a huge Job, I can have mine out and on the floor in about Thirty Minutes. Unhook The fuel line and throttle & choke Linkage's as well as the Hot side Battery cable end from the battery Post as well as Unhook the Negative Battery Terminal then Un-bolt it from the engine block. Unhook the engine wiring Harness, Remove the floor Pan, Unhook the One dead center top Hydraulic Line in the way of getting to the Flywheel drive shaft bolts. Take out The Four flywheel drive shaft coupler bolts, Take out the Four Oil Pan to Frame mounting bolt's, Unhook the PTO wiring harness, Pull The engine forward and remove it from the Frame. Once it is out and on the floor or bench the starter is easy to get at. Good Luck, Keep us Posted on how you made out. Regards, Hammerdown
