John Deere 318 front mount brush mower?
   / John Deere 318 front mount brush mower? #1
mblair441
Ira, Texas
1959 JD 730, 2017 JD 1025R, 1956 Ferguson 40, 1959 Farmall Cub, 1982 JD 318, Case 580B, JD 350B
My John Deere 318 has the mid mount mower deck, but has anyone ever seen or heard of a hydraulically (or belt) driven, front mounted field or brush type mower for a 318? Something along the lines of those walk behind DR field mowers, that could be attached to the front mounting points, and be raised and lowered or powered with the front hydraulics and used to cut through tall, thick weeds and grass?
   / John Deere 318 front mount brush mower? #2
Nope. Not near the framework, engine 18hp, or hydraulics on the 318 garden tractor to do that, I don't believe.
Maybe you could attach or mount a DR brush mower to the front of your JD 318 and move it around as it would use its own power to mow the brush.
   / John Deere 318 front mount brush mower? #3
Haban Flail Mower
   / John Deere 318 front mount brush mower? #4
It would be better to have a flail mower operate behind the tractor so less dust and clippings will be sucked into the tractor engine air filter, cooling system and the operators lungs!
   / John Deere 318 front mount brush mower? #5
The Haban flail mower was the Deere OEM version. The OP could purchase a gas powered tow behind flail mower.
2012 JACK COUNTY 130 BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
2014 Dodge 5500 4X4 Bucket Truck (A52748)
2014 Dodge 5500...
2020 JOHN DEERE 331G SKID STEER (A51246)
2020 JOHN DEERE...
Komatsu WA250-5L Wheel Loader (A52384)
Komatsu WA250-5L...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
RIGID TOOLBOX (A52472)
