John Deere 3120 compact electriical issue
   / John Deere 3120 compact electriical issue #1
kudu
wa
john deere model 3120
My JD 3120 compact was starting with no problem but after working it about 1 hour shut down for about 10 minutes then when turned key on to restart all the lights on the instrument panel randomly flashed and fuel shut off clicked on and off. When key was turned to start position the starter solenoid would temporarily energize and start motor would just click over a small increment. Have used a different battery, pulled off the start motor and solenoid and bench tested and it works fine. Would appreciate any advise on this problem.
   / John Deere 3120 compact electriical issue #2
Check your ground at the battery and where the cable goes to the frame, bad grounds on tractors are the biggest calls of electrical ghost. I have a copy of the deere technical manual in PDF that you were welcome to if you'd like it. Shoot me your email if you want a copy.
   / John Deere 3120 compact electriical issue #3
Hi joecdeere
Thanks for the reply to my question. Yes I would definitly like to have a copy of the manual you mentioned. Please send it to my e-mail address jxg522@aol.com
Again many thanks,
Jim
   / John Deere 3120 compact electriical issue #4
Joe,
My original name and password quit working so I had to re-register hence the different screen name.
Jim
Washington State
   / John Deere 3120 compact electriical issue #5
sending now
Joe
2000 MACK (A50323)
2000 MACK (A50323)
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
John Deere 2210 Compact Tractor (RUNS) (A50774)
John Deere 2210...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
