John Deere 3120 -- 4 wheel drive slipping
   / John Deere 3120 -- 4 wheel drive slipping #1
jmussio
Saanichton BC
John Deere 3120
When backing up hill with 4-wheel drive, I notice the transmission seems to be slipping. Just started happening. No issue in 2-wheel drive.
What's the problem?
   / John Deere 3120 -- 4 wheel drive slipping #2
What kind of transmission?
If a hydrostatic, I'd check the fluid level first.
It's a hydrostatic transmission. Fluid level is OK.
Also, yesterday I recall feeling a vibration in the PTO area when taking a sharp turn while using a sprayer in 4WD. I use 4WD often as I have a hilly farm.
I appreciate your help.
Jerry Mussio
   / John Deere 3120 -- 4 wheel drive slipping #4
Check the front drive shaft. There may be a coupling at each end and the splines could be sheared or the couplings shot.
Is it possible to easily check the front drive shaft? I hope to avoid having John Deere open up the rear transmi$$ion. In the meantime, everything is OK in 2WD and will use that until September when I harvest my vineyard.
Thanks for the suggestion
2021 DEERE 333G LOT NUMBER 198 (A53084)
2021 DEERE 333G...
2025 New/Unused Wolverine Vibratory Roller (A51573)
2025 New/Unused...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
City of Lakeland (A51691)
City of Lakeland...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
