John Deere 3120 -- 4 wheel drive slipping
   / John Deere 3120 -- 4 wheel drive slipping #1
jmussio
Saanichton BC
John Deere 3120
When backing up hill with 4-wheel drive, I notice the transmission seems to be slipping. Just started happening. No issue in 2-wheel drive.
What's the problem?
   / John Deere 3120 -- 4 wheel drive slipping #2
What kind of transmission?
If a hydrostatic, I'd check the fluid level first.
It's a hydrostatic transmission. Fluid level is OK.
Also, yesterday I recall feeling a vibration in the PTO area when taking a sharp turn while using a sprayer in 4WD. I use 4WD often as I have a hilly farm.
I appreciate your help.
Jerry Mussio
   / John Deere 3120 -- 4 wheel drive slipping #4
Check the front drive shaft. There may be a coupling at each end and the splines could be sheared or the couplings shot.
Is it possible to easily check the front drive shaft? I hope to avoid having John Deere open up the rear transmi$$ion. In the meantime, everything is OK in 2WD and will use that until September when I harvest my vineyard.
Thanks for the suggestion
JOHN DEERE 560M LOT NUMBER 37 (A53084)
JOHN DEERE 560M...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2006 JLG 460SJ Man Lift (A51573)
2006 JLG 460SJ Man...
2009 Kubota KX080-3 Mini Excavator (A51573)
2009 Kubota...
2023 John Deere HD50F Draper Head (A53342)
2023 John Deere...
