John Deere 310 hydraulic service
   / John Deere 310 hydraulic service #1
EricG1793
Hello,
We've been getting sluggish performance out of the FEL on our 310 and sometimes there's pulsing as it lifts up. Usually, adding fluid (there are a couple leaky hoses) seems to fix it, but it's been worse lately.
I would like to drain the fluid and change the filter. Has anyone here done this? Do you know the capacity, and any specific type of fluid? We have a couple gallons of John Deere fluid left over; would it be a bad thing to drain and finish that off and top off with another brand, or should we keep it the same? Is it just the one cartridge filter to replace, no screens or anything? Check the fluid with engine running or stopped? Besides draining and refilling, does anything need to be bled or will it work itself out with use?
Also, I was talking with a friend who has a 410 today and I used it briefly and his FEL behaves exactly like mine does. From what I understand, he said that there's a solenoid valve that will open the flow of fluid so the engine isn't pumping while it starts, and that this valve can get dirty/clogged and allow some of the pressure to release while it's running. Where is this thing and how can I deal with it?
Thanks for any information you can share!
   / John Deere 310 hydraulic service #2
Check & clean if required the hyd oil sump screen(parts key 30). I recommend JD Hy-gard oil. Tractordata.com lists 20.5 gal but that amount should be a totally dry unit IE NO OIL ever installed. 310 should have 2 hyd filters AR75603 Filter Element - ELEMENT,OIL FILTER ADD 7.96 USD
2011 New Holland B95B Cab MFWD Loader Backhoe (A55302)
2011 New Holland...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2008 DRAGON 150...
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
2013 COACHMEN CATALINA TRAVEL TRAILER (A52472)
2013 COACHMEN...
2019 Kia Soul SUV (A53424)
2019 Kia Soul SUV...
2006 Mercedes-Benz (A55758)
2006 Mercedes-Benz...
