John Deere 310 hydraulic service
   / John Deere 310 hydraulic service #1
EricG1793
Hello,
We've been getting sluggish performance out of the FEL on our 310 and sometimes there's pulsing as it lifts up. Usually, adding fluid (there are a couple leaky hoses) seems to fix it, but it's been worse lately.
I would like to drain the fluid and change the filter. Has anyone here done this? Do you know the capacity, and any specific type of fluid? We have a couple gallons of John Deere fluid left over; would it be a bad thing to drain and finish that off and top off with another brand, or should we keep it the same? Is it just the one cartridge filter to replace, no screens or anything? Check the fluid with engine running or stopped? Besides draining and refilling, does anything need to be bled or will it work itself out with use?
Also, I was talking with a friend who has a 410 today and I used it briefly and his FEL behaves exactly like mine does. From what I understand, he said that there's a solenoid valve that will open the flow of fluid so the engine isn't pumping while it starts, and that this valve can get dirty/clogged and allow some of the pressure to release while it's running. Where is this thing and how can I deal with it?
Thanks for any information you can share!
   / John Deere 310 hydraulic service #2
Check & clean if required the hyd oil sump screen(parts key 30). I recommend JD Hy-gard oil. Tractordata.com lists 20.5 gal but that amount should be a totally dry unit IE NO OIL ever installed. 310 should have 2 hyd filters AR75603 Filter Element - ELEMENT,OIL FILTER ADD 7.96 USD
2010 JOHN DEERE 1110E FORWARDER (A51246)
2010 JOHN DEERE...
1998 WELD-IT COMPANY FUEL TRANSPORT PUP TRAILER (A52472)
1998 WELD-IT...
2009 Lexus RX 350 SUV (A50324)
2009 Lexus RX 350...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2022 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2022 PETERBILT 389...
