Sickle Bar John Deere 3046R sickle bar SB3107 question
   / John Deere 3046R sickle bar SB3107 question #1
cooljoe00
Nichols, sc
Kioti NX6010HST Cab
I was looking at a John Deere 3046R, but I was checking the compatibility list of the sickle bar SB3107, and this tractor is not in the list. Does any one know why? or if there is a sickle bar out there that is compatible with this model tractor.
   / John Deere 3046R sickle bar SB3107 question #2
I run one on my 3320 with no issues
This is the article clip that I am referring to.
Sicklebar Mowers
Rough cuts made easy. Double-action cutting bar makes quick work of
ditches, hay fields and varying terrain. These Category 1 hitch-compatible
mowers include hydraulic-lift cylinders for the cutting bar.
69-in. cutting width 25-50 hp SB3106
3320, 3520, 3720, 3032E, 3038E,
4005, 4105, 4120, 4320, 4520, 4720,
4044M/R
81-in. cutting width 25-50 hp SB3107
4005, 4105, 4120, 4320, 4520, 472,
4044M/R
92.5-in. cutting width 25-50 hp SB3108
4044M/R
The models 3033R, 3039R, 3046R are not in the list. The only 'R' tractor in the list is the 4044R. I was wondering if there was so kind of reason their not in the list, or if they still work on the other 'R' tractor just not listed.
   / John Deere 3046R sickle bar SB3107 question #4
My guess is the list is just not updated with the current models.
   / John Deere 3046R sickle bar SB3107 question #5
I would also bet the list is not updated. What will you be doing with the sickle mower? Ken Sweet
mowing ditches.
   / John Deere 3046R sickle bar SB3107 question #8
What is "double action" (in regards to a sickle bar)?
   / John Deere 3046R sickle bar SB3107 question #9
The guard bar and section bar both move instead of just the section bar, as seen on conventional mowers. Ken Sweet
2017 Kubota KX080-4 Mini Excavator (A51573)
2017 Kubota...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
(2) Sumitomo 11.00 R22 Tires (A51573)
(2) Sumitomo 11.00...
2023 Bobcat E32i Excavator (A51573)
2023 Bobcat E32i...
2023 JOHN DEERE 8R340 LOT NUMBER 221 (A53084)
2023 JOHN DEERE...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
