John Deere 3033r
   / John Deere 3033r #31
DanM128,
I have a '10 3320 cab which is basically the 3033R with black chassis paint and fewer emission controls. I have a 59" blower and a 1100 foot driveway up in NH on a former ski mountain, we get a truck load of snow here and it goes as fast as the blower will throw it. The limitation of the ground speed with the 59 isn't the HP of the tractor, anything over 20HP would run it fine it's the fan stage is undersized for the width, also it has only 3 blades on the fan. Deere should look at adding 2 or 3 more fan blades and making the drum 2 or 3 inches deeper now that the smallest tractor that it fits on is the 3000 series.
If your debating tire choices, get the R3 turfs, they work really good with the loader and blower. You do need AC in the cab, even in NH that cab is like a green house if it's warmer than 70 out. On the other end of the spectrum, the heat is great when it's -15 and the wind is whipping the snow around. Get the air ride seat as well as the horn and backup alarm if you have people in the area you operate in, you can signal them easier with the horn and the backup alarm get's them to look. (I have found the dogs know what to do as well when either sounds, they picked up on that quicker then the kids did, kinda sad if you ask me)
Any questions, just ask,
Tom
Thanks for the good information. I agree with you on getting the R3's I have those now and plan on getting them on the new tractor. What is the height of your tractor to the top of cab? I have seen many varying heights depending on tires, etc. I am trying to see if I will fit in the garage.
Thanks again, Dan
   / John Deere 3033r
I can only attest to the R4's it fits fine in my 8 ft doors, I was in the same predicament and could not justify the increase from.a 33 to the 39 the tractor has been great I have but in over 20 driveways with no problems I either use the box blade or my go to is the land plane I have an rc 60 rotary cutter and 64 rear snow none of which I have used since upgrading to the 3033r cab however they tan fine on the the 3032e so I am not anticipating any problems I have been thinking about loading my rear tires with rim guard heard a lot of positive feed back
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A51039)
2021 John Deere...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A49461)
2007 Bomag...
2023 TAKEUCHI TL10V2 SKID STEER (A51242)
2023 TAKEUCHI...
1270 (A50490)
1270 (A50490)
