John Deere 3033r
   / John Deere 3033r #1
firefighterjrm
Bronze Member
Denton, Maryland
3032e D-140
Ok friends I am trying to get some feed back on John Deere 3033r with cab, I am currently operating a 3032e I mainly use it for driveway maintenance and snow removal my current equipment rc 60, SB1164 rear snow blower, 5 foot box scape and land plane my dealer is offering me 0 percent for 84 months which is only going to raise my current payments by about 20 bucks I am looking for anyone out with there experience with the 3033r with a cab positive and negative also if someone has this could you please tell me your total height I want to make sure it will fit in the garage I have seen varying heights from 85 inches to 96 thanks for your help.
   / John Deere 3033r #2
Can't answer positives and negatives on 3033R since I have an older 3720 model but the height of the tractor/cab is going to depend largely on which tires you choose. This was a real concern for me when I was buying. I actually measured the height of several 3X20 tractors at the dealer with R1's, large R4's and small R4's. Went with the small R4's at the time to ensure it fit thru the overhead garage door.
   / John Deere 3033r #4
Per the John Deere "build your own" tool, R4's can be either 15-19.5 6 ply rating (code 5220) or 43x16-20 4 ply rating (code 5230).
   / John Deere 3033r
I wonder what the difference is between both as far height thanks so much
   / John Deere 3033r #6
I have the big r4 on my 3320 cab its 90" from ground to highest point on cab roof . Just went and measured it.
   / John Deere 3033r
Thanks so much, I believe I am rite at 92 so it just might work I refuse to keep any of my equipment outside for storage anyone out there have a 3033r cab tractor just trying to get some feed back pros and cons thanks so much
   / John Deere 3033r #8
The 3 series and 4 series John Deere compact utility tractors are rebadged 3x20 series and 4x20 series, respectively, with some changes added. I can tell you my 2007 3720 cab tractor with just over 600 hrs has been pretty much trouble free. Only issue when it was new/delivered the A/C didn't operate as expected. It turned out to be a damaged/leaky air seal around the roof which encloses the A/C evaporator, fan, controls. Seal was most likely damaged when the roof was removed at the dealership to install the radio. That was covered under warranty. Oh, the battery had to be replaced last year but that can be expected with over 7 years of service.
   / John Deere 3033r #9
2012 3320 zero problems. everything works perfect. Could not be more happy with it.
   / John Deere 3033r #10
I have a 3033r with cab. It has R3's and is 6 inches too tall for a seven foot garage door.On paper it would fit.The R1's cab height is 85 inches .I could have let enough air out to it in the garage.R3's are alledged to be shorter. Not the case. I love the cab. I run the air conditioner and it will freeze your arse off.The hydrostat is a dream.The 72 inch mower cuts beautifully.If I could do over, I would buy the turf specials and chance the belly mower not fitting with out mods. The specials are shorter and fatter. I can not see any reason the specials would interfere with the mower. This is a very heavy tractor and will rut the yard if damp.But in all fairness my scag would do the same. Don't bother buying a radio you wouldn't be able to enjoy it. The noise is greatly diminshed but still too loud without hearing protection. I have about 30 hours and have not encountered any regen. If it has I didn't notice. I like both Deere and Kubota and have had both. This Deere was price competetive with other tractors it's size. It starts like a car and runs smoothly. Fuel consumption is higher than my last (2520), but it weighs twice as much and has air conditioning,( which I run all the time).
Set of AG R4 Wheels and Tires (A51039)
Set of AG R4...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
2002 International 9200i Truck (A51039)
2002 International...
2018 JCB 505-TC 5,500lb 4x4 Rough Terrain Telehandler (A49461)
2018 JCB 505-TC...
1981 Case 245 2wd tractor with Rotary cutter (A51039)
1981 Case 245 2wd...
2020 John Deere 870GP Articulated Motor Grader (A49461)
2020 John Deere...
