John Deere 300CX - Operating with Unexpected Shutoff - Where are the gurus?
   / John Deere 300CX - Operating with Unexpected Shutoff - Where are the gurus? #1
Dirigo88
John Deere 300cx
Hey all
I'm running into an issue with the farm's 300CX Loader. I could really use the help of the JD Gurus in here.
Here's the order of events:
- Brush-hogging some thick vegetation & mowing an access road around the perimeter. Tractor operation normal. PTO Operation Normal
- Disengage PTO Deck for approximately 100 yds, then re-engage. Operation Normal.
- Continue mowing for another 800 yds and the tractor shuts down. (Note: This has happened previously and after a weeks time, the tractor started right back up)
- Go to restart the tractor. The warning message on the LED display reads "PTO On". (Note: This is new)
- Disengege PTO Switch.
- Recycle ignition sequence—the same message.
- Exit the cab and assess the condition of the tractor. No leaking fluids. No broken hoses. The mower/Brushhog Attachment is secure.
- Hand spin PTO Shaft to try and possibly disengage any safety sensor.
- Recycle ignition sequence. Same message.
- I continue to assess the exterior of the tractor and noticed wires dangling on the starboard (or right if you were facing the back of the tractor) side, just forward of the rear wheel, dangling wires with 2 connectors. One appears intact, the other appears to have been disconnected.
The wiring harness appears to start forward of where the cable is currently held to the frame and transmission housing. The cable bundle clip is located just in the space between the cab and the PTO Pump body. I'm not sure which came first, as the PTO was engaged and in operation for a while prior to shutting down.
Any and all help would be great, and I would encourage additional questions, as I may have missed some info for you all to assess properly.
I have attached photos of the wiring.
   / John Deere 300CX - Operating with Unexpected Shutoff - Where are the gurus? #2
I’m probably stating the obvious but the trick is to figure out where that plugs in. I’d think by stretching the wire in different directions you could find it.
   / John Deere 300CX - Operating with Unexpected Shutoff - Where are the gurus? #3
Dirigo88,
Did you find a solution to your issue?
   / John Deere 300CX - Operating with Unexpected Shutoff - Where are the gurus? #4
What tractor is this?
300CX is the loaders model number, not the tractor.
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2013 International WorkStar 7400 Altec AM547 50ft. Bucket Truck (A55852)
2013 International...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2015 Chevrolet 1500 Silverado Pickup Truck (A55852)
2015 Chevrolet...
Pull-Behind Reel Mower Tractor Attachment (A55851)
Pull-Behind Reel...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
