John Deere 2950 hyd issue
   / John Deere 2950 hyd issue #11
I did look in the filler hole for the rear end, and it was misting on the inside. Also there is a small steady stream of oil running straight in from the filler hole towards the top.
Sounds as if RS control valve needs new seals installed which means 3 pt housing requires removal. I suggest to R&R 3 pt piston seals at this time. Is loader valve the convertible type that can be changed from CC to OC or vice verse? If so I suggest to remove loader control valve return line,with loader control valve in neutral start engine and if oil exits return hose then valve needs attention.
   / John Deere 2950 hyd issue #12
I am going to study what you said with this. The one I am working on has no hi low or reverser. I didnt pay attn to the pto operation yet. That pic of drawing on the 1st page is about like the one on 2640. I understand this is old. I was picking thru it.
I am going to test the valve on my 4020, should no flow on the return in neutral.
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
UNUSED LANDHONOR LDH-HT380 STAND ON SKID STEER (A54756)
UNUSED LANDHONOR...
2020 KUBOTA RTV...
TEST YOUR BID BUTTON! (A54757)
TEST YOUR BID...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
1993 JOHN DEERE 444E WHEEL LOADER (A52705)
1993 JOHN DEERE...
