JOHN DEERE 2840, HYDRAULICS WILL CREEP WHILE DRIVING.
   / JOHN DEERE 2840, HYDRAULICS WILL CREEP WHILE DRIVING. #1
cattlefarmer44
mt. zion illinois
JOHN DEERE 2840
ON MY JD 2840 THE LOADER WILL RISE AND BUCKET DUMPS, IF YOU HAVE ANYTHING ON THE BACK IT WILL RISE WHILE YOUR DRIVING. IT SLOWLY DOES IT, BUT IT IS ANOYING. DOES ANYBODY HAVE A FIX FOR THE PROBLEM.
   / JOHN DEERE 2840, HYDRAULICS WILL CREEP WHILE DRIVING. #2
Tractor data says your tractor is closed center, so no fluid should be flowing through the valves until you move the levers.
http://www.tractordata.com/farm-tractors/000/0/9/93-john-deere-2840.html
With all valves in neutral, the cyl's should not be getting any fluid, unless the valves are leaking.
It would be unusual for two valves to be leaking at the same time, but it could happen.
There is no logical reason for what you describe to occur.
Install a hyd pressure gage on the cyl side and take some readings.
Note especially the pressure when the cyl are fully extended.
   / JOHN DEERE 2840, HYDRAULICS WILL CREEP WHILE DRIVING. #3
i've run across this problem several times and it always wound up being the linkage cables from the joystick to the valves hanging up or the adjustments were off due to wear
   / JOHN DEERE 2840, HYDRAULICS WILL CREEP WHILE DRIVING. #4
The 3pt hitch on my JD 2030 (closed center) drfits up when running. The control lever also is drifting up. I think it needs the friction washers from the lever to the quadrant replaced. Just heve not bothered to replace them:ashamed:
   / JOHN DEERE 2840, HYDRAULICS WILL CREEP WHILE DRIVING. #5
It could also be either seals leaking on the valves or what I've seen called a "sponge" or "spongy" casting for the valves which let's fluid slowly bypass the valves completely. Just something to check.
   / JOHN DEERE 2840, HYDRAULICS WILL CREEP WHILE DRIVING. #6
i know this is an odd question but does the tractor have the emble on the fule tank missing? i know this is an odd question but i think i may know which tractor you have please give me an email at nickroepke2@gmail.com thanks and i hope to hear from you
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2012 Ford Expedition XLT SUV (A51694)
2012 Ford...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
New 40ft High Cube 6 Door Container (A53002)
New 40ft High Cube...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
