John Deere 27C starter
/ John Deere 27C starter #11
From the pictures I see of you machine there has to be a access cover under your seat
Thank you for all the suggestions. I got it running. It was the ground as a few of you thought. I still have a couple of questions. I tried running a jumper cable from the negative of the battery to the engine compartment. The engine looks painted so I didn't try that. Would that have still worked? Instead, I used the metal latch that's bolted to the frame. It is steel with a gold finish that I guessed would conduct electricity. The engine started! I found where the black wire went to the frame. It all looked fairly corroded. I replaced the ground wire and cleaned everything up. It now starts fine.
Another question: What causes the white powder corrosion? Is it a sign something else is wrong? Will it be less now that I've established a better ground? If anyone reads this and knows how to access the side of the engine facing forward; I would still like to know. I'm pretty sure it's not under the seat, although that's possible, a lot of stuff would have to be removed. On the left side, there's a panel that the fuel filler comes through. Only three bolts appear to hold that panel on to the frame. I can see the inside of it from the back engine compartment hatch. My only hesitation is the fuel filler. There's a rubber seal between it and the panel. Do those usually come off and go back on easily?
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
(INOP) BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) BOMAG...
New Quick Attach Hay Spear (A61166)
New Quick Attach...
2022 Kubota SVL97-2 (A60462)
2022 Kubota...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
