John Deere 2720
   / John Deere 2720 #1
Kubota B7800
Kubota B7800
I just bought a 2720 with a 200cx loader and a 46 backhoe attachment. The tractor has one leak around the rear end and the backhoe has several leaks. Does anyone have a pdf service manual that you would share?
   / John Deere 2720 #2
It's still a current production tractor and the manual is available through Deere at JDparts.com. Basically it's illegal to do what you are asking and would be against the rules of the forum so you may not get many offers....
The parts diagrams are also available on JDparts so you may be able to look at them and figure out what you need as well. If you can positively identify the area where it is leaking you should easily be able to check for loose bolts or at least identify which gasket is leaking unless it's the power beyond hook up that's leaking from a bad o-ring. Unhook all the hydraulic quick connects and clean and inspect them.
5K BLOWOUT PREVENTER (A50854)
5K BLOWOUT...
2017 HINO BOX TRUCK (A51222)
2017 HINO BOX...
2020 KUBOTA RTV...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
