John Deere 2720 - Kanzaki Hydraulic Pump
   / John Deere 2720 - Kanzaki Hydraulic Pump #1
smashedtoe
John Deere 2720, 5055E, 6175R and 9620RX
Hello all,
I am looking for a rebuild kit for the Kanzaki PW1-D-8A hydraulic pump off my John Deere 2720 utility tractor.
Interanal rubber gasket/seal (?) is broken and I can not justify spending $700 CAD on a pump when the aforementioned seal is the issue.
Anyone here know where I can find the kits? I looked online and with John Deere; no luck.
Thanks in advance
Hello all,
Thanks in advance
After days of searching and endless dead ends, I have come to realize if my name doesn’t contain the initials “JD” I am not obtaining a pump rebuild kit anywhere.
I certainly engaged a great deal of helpful people between Japan throughout North America, however; $$ talks.
Here you go JD....($700)
This has been an interesting repair.
John Deere Parts Dept. tells me John Deere is no longer producing the pump and was unable to provide an answer as to where I can find one (suggests eBay.....true story).
After some research, I contacted the Yanmar dealer as this is the engine in the tractor and they are able to provide me with a pump!
Pump ordered and installed, however, after 45 minutes of using the tractor, I shut it down for breakfast and upon my return, the hydraulics quit working.
Out of frustration, I parked the tractor in the shop for three days and decided to unbolt the rigid outlet pipe from the pump to see if oil was pumping, after about one second of the tractor running, the oil started to flow. Bolted the rigid pipe back on and the hydraulics worked (I was so excited I did a little dance).......but wait ☹️
Yesterday morning I was using the tractor and the hydraulics would pause or quit working after I would shut the machine down. I would check the hydraulic sight glass to find the oil level low, so I would add a little oil and away it would go; all ticking-boo again.
Then the epiphany......
I shut down the tractor and pulled the engine oil dipstick and the oil was higher than some after the legalization of marijuana.
I removed the NEW hydraulic pump to chase down my suspicion of a leaking seal and God dammit my hunch was right! Not even two hours and the seal (obviously defective) was allowing hydraulic oil to pass into the engine. After speaking with the Yanmar dealer the folks in Atlanta wanted the pump back to test it.....
Thankfully the good folks at the farm supply store were able to provide a replacement seal and I am movin’ and groovin’ once again!
Wow.....what a ride this has been.
2021 BOBCAT T450 SKID STEER (A51246)
2021 BOBCAT T450...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A53472)
Kubota SVL65-2...
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
