Rear Finish Mower John Deere 272 Finish Mower
   / John Deere 272 Finish Mower #1
JohnLoeffler
Spokane, WA
Kioti CKI 30
I have a John Deere 272 finish mower which I use with a Kioti CK30 tractor. The only purpose is to keep my 5 acre lot cut. I have planted field grass and mow the field about once a month. The mower's blades have been sharpened regularly. The mower really does a poor job of cutting. I originally thought I would get a brush hog but decided the finish mower would leave a better looking cut. Any one have experience with this mower and any suggestions on improving the look of the cut?
Thanks.
   / John Deere 272 Finish Mower #2
Poor as in what?
What are you trying to cut?
Are you running your tractor up at PTO speed?
The mower leaves intermittent grass uncut. The cut is not smooth at all. The grass is field grass planted two years ago. I run the tractor at full PTO speed.
Thanks.
   / John Deere 272 Finish Mower #4
If you slow way down does it cut better?
If so (if it doesn't have them already) I'd consider a higher suction blade.
It cuts a little better but not a lot better.
   / John Deere 272 Finish Mower #6
How tall is the grass when you cut it? What height are you cutting the grass to?
   / John Deere 272 Finish Mower #7
With a finish mower you are going to have to mow more than once a month to get a smooth cut.
Thanks but I have mowed when grass is only 6 inches and it still does a poor job.
Usually my grass is about 8'' to a foot. I'm cutting to the lowest setting on the mower. (I have experimented with raising the wheel setting, even to the highest setting).
   / John Deere 272 Finish Mower #10
Does your 272 have 4 gauge wheels or just 2 on the back? If just 2 in back be sure the mower is level, and the front lip isn't dragging the ground.
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
2015 ford f350 4x4 mechanic SERVICE TRUCK (A52377)
2015 ford f350 4x4...
SELLICK S80T4E-4PS ROUGH TERRAIN FORKLIFT (A51246)
SELLICK S80T4E-4PS...
480/70R38 LOT NUMBER 135 (A53084)
480/70R38 LOT...
JOHN DEERE S780 LOT NUMBER 36 (A53084)
JOHN DEERE S780...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
