jars22
I have a 1995 262 lawn mower tractor that does not recharge the the battery while you are running the tractor any help would be appreciated thanks
Sorry should have told you it has a kawasaki 17 hp motor thanks
Most Lawn Engines design with the same principle, even with your Car, LOL But Cars got more Parts / Stuff......
Read those links first... You'll find the same stuff with your Engine... Like Coil, Solenoid, Fuse, Stator, Starter, Wiring trouble shooting... Try to understand how things work, then it's a lot easier to trouble shoot.
How old is the Battery? Could just be a Bad Battery... Sometimes the OLD Battery got Drained due to Bad connections or Ignition key was left on with bad wiring and go to Lower than 1/2 of 12V. It doesn't charge no more after that... The best is to get a Battery Charger and then Jolt it for like 15 mins with like 10AMPS... Then let it sit overnight with 2AMPS... I was able to Relive it to my Battery doing that, also I found a BAD wire...
Do you have a Tester / Volt Meter? Try testing the Battery... With the Link above. Also, you can take the Possitive Cable out of your Battery while your Engine is Running, Test it with a Tester to see if you get Juice +++ If your reading is Possitive +++ than it's the Bad Battery...
